Chain changing tension as it rotates
STOVE
8:11 PM
Eastern NC
Noticed something strange this evening while tinkering in the garage. I mounted up a bar and chain on my ms390.
The bar, chain, rim and sprocket have less than a tank on them. When I rotate the chain it gets tighter and looser within the revolution. It ranges from proper tension to go cut, to seeing 4-5 drivers. The sprocket is a rim setup from the Dukes. Chain is Dukes, bar is Oregon.
What is going on here? Am I crazy to think the china sprocket is out of round? I should have gone OEM, but I just want to troubleshoot it first
EFSM
7:11 PM
Extreme southern IL
I’ve seen this and it’s usually inconsistency in the chain, but it could also be an out of round sprocket on either the clutch or bar tip.
legdelimber
8:11 PM
N.C.
Get the chain rolled around to either a loose or tight spot.
Make a sharpie mark on one spot of the rim/sprocket. Also make a mark on the chain
Keeping track of the marks, roll the chain completely around a few times and take note if the marks shift apart as you do this.
If you have two colors available, mark a tight spot with one color and a loose spot with the other colors.
If the color spots drift away from each other its most likely the rim or possibly clutch related.
Using two colors or different shape marks will make it easier to keep track of the tight and loose spots
STOVE
8:11 PM
Eastern NC
Try a different chain on the saw. I had this happen and it was the chain.
I’ll toss a well used loop on this evening and see what happens.
From what I’m seeing it could be uneven stretching of the chain which could work itself out
Junk Meister
7:11 PM
Nebraska
Yes , both 3/8
YES Both 3/8" but is one a LP/Picco?
Pull the (I assume it is) rim and chain and see if th chain sits/saddles in the rim sprocket all the way around for a proper fit.
Something easy to overlook but you still have a problem so it is time to shake up the IDEA basket.
Then do the Bar sprocket so you can X that off the check list.
STOVE
8:11 PM
Eastern NC
I've seen it with no-name rims. Calipers confirmed out of round between inner spline and outer rim. SMH
Called a local shop and will be grabbing a Oregon to see if that fixes.
I’m going to measure the Chinese one tonight and see how it measures between each spline
dangerousatom
8:11 PM
Quakertown, PA, United States
My money is on a tight bunch of rivets or sloppy holes on the chain. A bearing, rim sprocket or nose sprocket will not give that much wiggle room, unless they are all bad and keep falling on their bad spots at the time as the chain passes......near impossible IMO
One of the reason I keep my used/dull chains in a gallon paint can with like 1' of WD40 in the bottom. Every time i put in a dull chain the can gets a turn over to mix it around. When I decide to sharpen they all get hung on a peg and drip back into the can while im working on one.
