FergusonTO35
- 2:15 AM
- Jul 9, 2017
- Boonesborough, KY
Yes, this will be a lifelong process!
I haven't used it much but the welds I made have held so far. I welded an Echo muffler back together after modding it and the muffler has held together just fine. I think this welder is ideal for sheet metal and quick and dirty patch jobs. It's definitely no substitute for a stick welder or even a 220 volt mig. A buddy is supposed to bring me a mower deck to patch so I'll let you know how that goes if he does bring it.
In hvac school we had to be able to solder 2 pop cans together in order to earn an A. After that brazing copper line-sets were a breeze.Welding just takes practice .My favorite welding story on another forum .A typical California know it all said I couldn't weld --sooo I gas welded two tin cans together and then the silence was deafening .![]()
For brazing hvac refer lines nothing less than a high quality 15% silver brazing rod will do in my humble opinion. I like and have almost always used stay-silv 15 rods but they’re pricy.Silver soldering is a real art form and can be incredibly strong. I would love to learn how to do it. What kind of solder do you use on copper? I wonder if it would also work on thin steel or aluminum?
No those would be considered brazing rods so they melt above the minimum 840 degree solder/brazing threshold. A small portable Oxy-acetylene torch would be the best choice. I’ve done brazing with a mapp torch in a pinch. It can be done but it’s really easy to mess the copper up with a mapp only torch. If you don’t have an oxy acetylene torch one of those little portable oxy/mapp torches from blue flame will get you by for the occasional small job. But you will spend way more in the long run on the little disposable tanks.Awesome. Can an ordinary propane torch be used for 15% silver rods?
I’m not sure. I purchased my tanks/torch through the Votech school I attended 20+ years ago. They were supplied by the local gas fill company.Thanks. Yeah, I think a real torch set and tanks is next on my list. Are the Gas Pony ones at Tractor Supply any good? They are supposed to be USA made.
