Case gasket material
JonCraig
10:33 PM
Tennessee
I need to make a NLA case gasket. Thickness is 0.02”. Anything I need to look out for/avoid when I go to my local parts store to buy sheets of gasket material?
Thank you!
11:33 PM
Well the thickness of the cardboard on a 24 pack of Bud Light is 22 thou if that helps .That aside about any of that typical brown gasket paper should work .Most of that stuff is rolled up in a tube .You about have to lay it out flat on a table and put a couple big books on it for a couple days to flatten it out .
Lone Wolf
11:33 PM
Nj
Water will make it lay flatter fast just wet it.
Lone Wolf
11:33 PM
Nj
Basher
12:33 AM
Canada
Fel Pro lists the thickness as .063. Will 3x the thickness as OEM be an issue?
Fel Pro sells many thicknesses of this type gasket material, do a google search for their site and there will be several to choose from. I know of 3 sizes I have used, 3054 is .063, ...3046 is .031,...3011 is .015. There may be more so a search will likely reveal those sizes and numbers. I would choose a size relatively close and go with it.
