Carb for 462
Redfin
Meh...
3:15 AM
Central Pa
I have been looking for a suitable carb to use on a 462 for some testing. I have no issue swapping shafts to use the existing throttle arm.
I have not found one yet with correct mounting orientation. At this point, I need help finding any carb that could be modified.
Id like to keep the oem throttle arm and mounting studs. I thought maybe some would have a larger selection to look at than I.BBE260F8-7F6A-407B-A5EB-4262D0826110.jpeg29F78B5C-05A1-4384-864A-5170DF921EF1.jpegC26F42C5-F251-44B6-8554-F4F63D923A4A.jpegB84B6FEE-7534-4DE5-AD5C-D60277AB9384.jpeg0343DF30-3BCA-44C4-8A74-6D939AB4A67A.jpeg
Lightning Performance
3:15 AM
East of Philly
Your much better at this than I but maybe a large Dolkita carb body flipped over wearing some other feed tubes...just a thought.
Redfin
Meh...
3:15 AM
Central Pa
Yes forgot to mention, I dont care where the impulse and fuel inlets are.
I did try a WJ69 turned inside out. No bueno.
Fruecrue
certified hand catcher
3:15 AM
Alden NY
Choke and air filter are a must have for you right?
DND 9000
9:15 AM
Germany
OEM Carburetor 1142/00 (1142 120 0600)
3:15 AM
Zama c3m like a 7900 right? Maybe try a hd12 off a 372, should bolt right on.
Fruecrue
3:15 AM
Alden NY
I have a couple 281/288 carbs here-HS228c and 283b.
Bolt pattern same as WJ I believe, let me know if you need pics or sumfin.
Also have some oddball WJs too if that helps.
Redfin
Meh...
3:15 AM
Central Pa
I have 1122s, 1128s, rjws, 228s. Nothing here with the correct orientation to at least bolt up and allow shaft swap to utilize oem throttle arm.
I fully expect to have to rebuild carb box and possible use a cable if I can not find one to bolt up for what I want to do.
nohoff
professional flusher
9:15 AM
Germany
i have 5 carbs for the MS 462 in the system
1 without M-Tronic
2 with Mtronic and without Heated Handles
2 with Mtronic with heated Handles
difference on the Mtronic carbs is the solenoid: old black or new white
Evansaw
10:15 AM
Greece
1 without M-Tronic
But it v3. All mtron carbs should be white solenoid. Anyway I didn’t count all editions as you did and I should
Redfin
Meh...
3:15 AM
Central Pa
My goal is to find a carb without the separation for the strato feed. I want to mount a standard bore on this saw.
