Jimmy in NC
- 11:28 PM
- Dec 23, 2015
- North Carolina
![United-States Country flag](https://opeforum.com/data/files/flags/shiny/32/United-States.png)
So I've had a box of 026 kicking around and I'm tired of kicking project boxes around. I decided to put it together and play with the ports a bit just to see what I can do. I've done more stock rebuilds than I care to remember and it's time to see if I can handle a twirly bit too...
So I built it with as much Asian flavor as I could .. well because it's a budget build for me. Saw went together well and cranked with no fuss. It's wearing a Farmer Tec 44.7 jug and piston with no base gasket. Squish is at 0.026-0.027". Carb has been both an AM carb from Dave and a rebuilt WT-194 carb. Saw cranks cold and warm, idles all day. Comes off idle like other 026's I've had (stock saws)... not my ported 346.. but not a stock 088 either.
The problem is I cannot get it to go over 13,000 rpm.. I did see 13,200 once.
The jug I cleaned up the casting flash, modded the muffler (mild), and barely widened the exhaust. None of the ports were changed other than some beveling. Same Farmer Tec shape and size.
I shaved 0.012" off the key to advance the timing.
Saw is blowing 190 psi according to my Echo gauge.
My question is this: Can the jug timing be off so bad that it will not go over 13,000?
I plan on trying to run it with the air filter removed this afternoon to see if that makes a difference. I do not think the shutter is being sucked closed, but I want to remove that as a possibility. Next step is to pull the timing advance out of it. I doubt it's over advanced as it cranks well and idles well but I can remove it to eliminate a possibility.
The only other thing I know of to do is clean up the OEM jug and buy a 44mm piston for it.
Any of you experienced porters have any ideas or thoughts? I think that if it was lean for fuel it would go to the moon. I can add fuel and take fuel away and it simply will not go over 13k. I can only come up with the thought that it just cannot move enough through efficiently to turn any higher.
![bd993080c0b6b1395f7601c9f97df4ae.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2Fbd993080c0b6b1395f7601c9f97df4ae.jpg&hash=f3f585362ce1554f40342ae4ba05dad2)
![74438352934075e9540c65c5d11615ee.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F74438352934075e9540c65c5d11615ee.jpg&hash=d1dc4cb4d5a672c1cc35909512e998f9)
![162c56e4abb2b06808d96bf151f77404.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F162c56e4abb2b06808d96bf151f77404.jpg&hash=684309d6ba3c57de998df460390de591)
![6372833b79f3b01b36390d03c2e99844.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F6372833b79f3b01b36390d03c2e99844.jpg&hash=b668dc4c30ec7c0797f754c199d28127)
![1ec8940ae92ad758398dd1ebca277fd8.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F1ec8940ae92ad758398dd1ebca277fd8.jpg&hash=eb0daf92cd9c7ecde19a4db57b6b566b)
![5be6e552b4e01f6bf8109ac30e018447.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F5be6e552b4e01f6bf8109ac30e018447.jpg&hash=da5a07695f19567944f99d63ed048cfa)
![904c1e3b3cbc8d824b7756b8d65f22f2.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F904c1e3b3cbc8d824b7756b8d65f22f2.jpg&hash=567a31786d548c1279dfa4b5509a5ac6)
![66f504296a7c8d2472c7072ca012657c.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2F66f504296a7c8d2472c7072ca012657c.jpg&hash=04b175a8db36c21d1b7e0d4b86b0f67d)
![df94b5c3055e9087a5275982aa36321f.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190227%2Fdf94b5c3055e9087a5275982aa36321f.jpg&hash=c05945bfb0dc849db3de349b8264173c)
