- 4:31 PM
- Dec 30, 2015
- Georgia
Nice one Randy, was that in the set you got from me? Never tried to use them on anything bigger than a 372
I have the same toolbox,old Craftsman. Was my Dads old box,my first tool box i painted it red and covered the front door with decals when i was in school.
Part number?
Shindaiwa studs also press in. I have used a telescoping magnet through the oil fill hole to get them started into the case, then used a bar nut and stack of washers to pull them into position until seated.
Do the Jonsered studs have inadequate clearance when the case is assembled to perform the swapperoo?
Do you ever tap them out, place new ones in with forceps, set with a long punch and tighten in with bar in place?
Part number?
Which saws does it fit on?
Does it work on both sides of the crank?
Why is the sky blue?
Why are my boogers green?
I just heat the case up and they fall on/off
Integral seal on the PTO side of the 2188 Brewz, heat will wreck that $55.00 bearing.
Yes sir. And then there are the fragile as hell 5 series saws.
I use heat to seat the bearing in most cases, but I've yet to find anything that works better than pulling the crank into the bearing.
I think I have 4-5 crank mounting kits, this one reminds me of 545/550/555/560/562 kit.
After I bought the first kit it's hard crank them together without using the toolluckily my dealer let me buy those kits for their cost price
Is the inner race supported as it goes onto the crank?
it depend on the kit, or more correct, it depend on seal dimension.Is the inner race supported as it goes onto the crank?
last time I bought it was around 20-22$ for a kit.Still ain't cheap.![]()
I noticed that Joe said yes, and I said no to the question about the inner race. Yes, it is supported on the PTO side, but not on the flywheel side.
The Stihl tools are far more complicated, and don't support the inner race on either side.
