Buyer Beware ????
hacskaroly
2100 Fanclub Member
1:07 AM
Northern Idaho, Ehh
The customer waited 15 months for his saw to be done....and this is the work he got.
I don't have an eye to tell if it's good or bad since I don't port. It looks clean, but the question I would have (that I would understand about it) is did it run, did it run good, Ok or crappy? I am guessing crappy since it is in your shop. Were the holes enlarged too much?
3:07 AM
Here's the real problem....
3:07 AM
I would take .020 off the flywheel key and apply it to the plating with electrolysis. No new cylinder.
Stage 3
Welp....the timing wasn't advanced.....so, maybe. Carb limiters were completely gone too. Sure fire way to bend the fugh outta the needles with a screwdriver.
mainer_in_ak
12:07 AM
Interior Alaska
Another technique you can use is quad port to dual port transformation. Just grind it all away.
Stage 4
3:07 AM
I thought the "texture was rough" so thanks for posting what not to expect.
Rough in the transfers and intake ain't really a problem. A burr finish is even fine. The intake port shape is terrible though.....but that's not a big deal really. It's the area between the upper transfers the made us decide to replace the cylinder. The muffler had a coating of fine metal dust inside of too....from the muffler mod. Lots of little things that just weren't Kosher.
