Marshy
WFO Cutting
- 11:23 AM
- Jan 5, 2016
- Mexico NY
I'm considering building a 3 point log boom for skidding trees. I eventually want a winch so I want to build it with that in mind. Anyone build their own?
I have a class 5 hitch receiver that I'll be using for this build. Right now I'm just browsing what s out there and the features I want and should consider before I build it. Here are some I found on the internet.
This is about as simple as it could be but this design has no way to incorporate a winch with the center support.
I was considering making the lower half more open like this, but keep the top half so ijt has the cantilevered boom part to hook chains to.
Mine will have the receiver just like above. I was thinking I could mount a winch to a plate and square tube to slide into the receiver. Because it's a class 5 receiver it has a 3x3 opening for the receiver so I was thinking I could use both sides of the receiver and make a blade attachment for the other side of the receiver (tube inside of a tube, ie one side uses the 3x3 and the other side uses a smaller tube to fit inside the 3x3). Making them removable seems appealing to me at the moment.
Here is one with a pivoting boom. I could add this as a feature. This would scissor the boom when you lift the 3pt and it has an open center for the cable. I'm thinking of making the frame like this so it scissors. Besides, depending on the lengths it will give me mechanical advantage when lifting.
I would hang a block under the boom like this.
I'm just not sure what winch it will have or how much room I will need for it. This is going on my 32 hp Deutz-Allis with a Cat 1 3pt. Im not building a skidder, just something to get the logs off the ground primarily and possibly to winch them 20-30ft.
Any recommendations for a winch? Trees will be 20-24" diameter max. If it's too heavy I'll cut them shorter. This is for firewood. I appreciate any input.
