Briggs & Stratton 5hp request.
bmp01
Active OPE Member
5:05 AM
Uk
Hello,
Does anyone have the service manual for 5Hp B & S engine model no 135212 0252-01 ?
If not I'll just dive in, looking to overhaul the carb and check / set valve cIearances while the carbs off.
The engine if strapped to a generator, it's dropping 400 pm going from no load to 2kw load and the plug is white... wants a bit of time spent on it, poor old thing.
Thanks,
bmp01
ray benson
11:05 PM
nw indiana
I have a few manuals but not sure which service manual is needed.
bmp01
Active OPE Member
5:05 AM
Uk
Thanks Ray. Give me a minute and I'll go and take a picture or two.
Also I believe the B & S manual 270962 covers a range of engines, this is one of 'em.
bmp01
Active OPE Member
5:05 AM
Uk
Does that help ?
bmp01
Active OPE Member
5:05 AM
Uk
Big thank you to Ray, thats a great help and going to set me of in the right direction.
Fantastc :thumbup:
Hugo
Active OPE Member
12:05 AM
Chile Temuco
Hola
¿Alguien tiene el manual de reparacion para 5Hp B & S engine model no 135212 0252-01 ?
Si no, simplemente me sumergiré, buscando revisar el carbohidrato y verificar / establecer cIearances de válvulas mientras los carbohidratos se apagan.
El motor está atado a un generador, está cayendo 400 pm pasando de no cargar a 2kw de carga y el enchufe es blanco ... quiere un poco de tiempo dedicado a ello, pobre cosa vieja.
Gracias
bmp01
espero que te sirva
