jmssaws
Banneded
- 8:50 PM
- Dec 28, 2015
- Missouri
The more you grind on the transfers or the bigger you make them the less exhaust duration you need.
Your taking tourqe away by hogging out the transfers so you have to get it back with the low exhaust and they run good.
Took me a while to figure that out.
Rpm will come from the transfers and not necessarily the exhaust height.
If I'm going to be over square on anything it will be on the exhaust, I want less intake to build case compression and feed the transfers.
I don't think about transfer height all that much,instead I think of blow down and set them off the exhaust height.
I done this 394 yesterday, it's 98.5 117 82
