Big bore and stroked Husky 395 build.
smokey7
11:30 PM
Detroit
How close is it jim? Im guessing you have eyeballed this a fair bit? Bolt pattern similar/workable? Stroke difference?
Chainsaw Jim
Con Artist LLC
8:30 PM
Springfield Oregon
I haven't found a wrist pin bearing that makes the gap. I think a sleeve might be useable, but more measurements are needed to know.
I can't remember exactly, but I think the bolt pattern was close enough to work.
This was sent home with me the other day to turn into a race saw. It has the 090 top end on it and may also get fitted with a chamber pipe. Here in a couple weeks I'll have it apart to do a mock up with the 111 too.
Wolverine
dilligaf
11:30 PM
This is the best I could do for big bar with the wood I have around here. 42" bar, noodling some cherry that's been down for a year, 8 pin, half skip square ground chain. Anyone want a couple of nice shelf boards?
Awesome! This is all I got:
Chainsaw Jim
Con Artist LLC
8:30 PM
Springfield Oregon
I’ve got you .
Ktm Sx50 clutch bearing . Part number # 45132015000
ID 15mm
OD 18mm
L 17mm
I’ve used that bearing as a wrist pin bearing for quite a couple big cc and HP builds and it’s a very high quality bearing that can stand the load and heat .
:headbang:
It just so happens that a KTM shop just opened up about 6 blocks away from me.
Lightning Performance
11:30 PM
East of Philly
Sty57
10:30 PM
Land of Cheese & Beer
It's an NWP big bore kit, using the supplied piston and split ductile rings. No two piece head. WJ-71 carb adapted to fit the 395 boot and throttle cable. The crankshaft is a 2100 that has been cut to fit a 395 flywheel. It's built as a work saw, I'd put it on a chainsaw mill and let it eat without any worries.
I wish I could get better rings for it but caber doesn't make 58x1.2mm rings.
Would there be enough meat in the jug to bore it to 60mm and run a 088/880 piston?
Nutball
10:30 PM
Mt. Juliet, TN
I'm out of pictures so we'll just cut to the video of it running. It was a rough day trying to get to testing. I ran 3 different coils before I found a suitable one. I still think this one may be loosing sparks at high RPM but it wasn't as noticeable as others with the timing light. I have a known good coil that I can pull off my other 395 some other day. With the timing light on the saw I also noticed the china 394/395 coils are much different timing than an OEM, not a good deal.
Are you going to run this at the MMWS GTG this year?
