Big bore and stroked Husky 395 build.
Jimmy in NC
8:59 AM
North Carolina
I'm out of pictures so we'll just cut to the video of it running. It was a rough day trying to get to testing. I ran 3 different coils before I found a suitable one. I still think this one may be loosing sparks at high RPM but it wasn't as noticeable as others with the timing light. I have a known good coil that I can pull off my other 395 some other day. With the timing light on the saw I also noticed the china 394/395 coils are much different timing than an OEM, not a good deal.
So stick to OEM coils on these...interesting.
Sent from my SM-G920V using Tapatalk
7:59 AM
Find a 2100 crank... machine it on your lathe. Bam! You have a crank.
I'm not a great machinist. Getting the taper right would be tough. Also, I'm not sure my lathe is rigid enough to cut through the layer of hardened material.
Tractorsaw1
7:59 AM
SHOW ME MO
Thanks for sharing and enlightening me - this was similar to what I was thinking when I asked about the 066 crank in the 2083 build
