Sid Post
Active OPE Member
- 4:34 PM
- May 20, 2016
I know Honda generators have near-legend status for many people in many applications but, boy are they expensive. I am not interested in the no-name cheap big box store options either. I have a Generac GP3600 which works well but, lacks 240V service and a clean power inverter. Great for general chores but, not really powerful enough for some applications and won't run my welder which is a small unit but requires 240V service.
For general use with electronics, think laptops, cellphones, radios, etc. along with other simple things like a coffee maker or little fridge at the lake, does anyone have thoughts or comments on the portability and flexibility in pseudo-recreational use of something like the Generac iQ3500 or GP3500i versus anything else in the ~$1,000 range? Sure, I would love to have the Honda equivalent but, >$3K ain't going to happen!
For more Agricultural and Ranching focused usage, how does something like the DuroMax XP12000HX compare to similar options from Generac or other well-respected brands? I should note this unit specifically is available for a touch over $1K delivered to me with a $200 gift card. I have limited experience with this brand but, it seemed to work fine when I ran one. With a sustained ~9.5Kw, it should drive my portable welder, water wells, and other big loads well. My goal here is to keep normal loads at 50% or less of the sustained rating so the fuel burn is not too bad and run times are really long. At ~200 lbs, I realize this is a tractor-loader or trailer move option only! I'm not saying I would not drag it a few feet but, the lightweight Generac GP3600 is a pain to drag around and I can lift it by myself into a pickup bed if I need to.
In summary, I am thinking about the best value (not the cheapest) in the $1,000 each range at the moment in TWO GENERATORS. I can spend more if there is a real reason and I will get the value out of the more expensive option. One needs to be practical for a car trunk, SUV, or use around the house where clean 120V power is needed to run lighter loads, everything from aquariums to computer electronics to light handyman tools, and the other needs to be more robust to run remote welders, water wells, high power lights, and similar things in a cow pasture from a tractor or trailer.
TIA,
Sid
TIA,
Sid
