Best way to loose comperssion? 064
Moparmyway
Its just a saw
2:01 PM
In a meeting
I need to do some learning on that.
Just get in there and give it a try.
Youre already cutting squish by spinning ............... its just turning a different feed screw. Hardest part is deciding on what angle to cut it at.
I've been cutting a taper in the squish for a while now, once you've done it one time, you can do it anytime.
lwhaples
2:01 PM
Vt
Looks easy enough. Thanks! Took your advice awhile back,when I (bed in my chuck?) worked Sweet.
Glock37
2:01 PM
Monroeville Pa
Do it have a dual key flywheel make sure its in x slot
czar800
2:01 PM
Ellwood City
How hard was the saw to start when you had it running? If you switched carbs because the first one wasn't right then maybe it really got flooded with fuel.
lwhaples
2:01 PM
Vt
Just as hard. Buddy of mine was doing the pulling. I started it the day before,but the more I pull the less I can do it. Kind of an age thing and bad body parts.Different carb was just me wanting to tweak things.
Definitive Dave
Piss Rev Mafia Member
2:01 PM
Central Ohio
Mike makes a good point, the 064 coil will not fire till it gets to a really high rpm, i cant remember off the top of my head but north of 12,000 i am pretty sure, many other models do not have this type of cut in especially at such a high rpm.
Glock37
2:01 PM
Monroeville Pa
You have to spin it fast enough for spark to make if not no sparky
lwhaples
2:01 PM
Vt
A lot of good info! You guys are awesome!
