malk315
Running Saws for Therapy
- 8:01 PM
- Jan 6, 2016
- Lancaster, MA
Hey guys -- apologies this isn't saw related, but one way it is connected is the bearing pocket on this pulley is just like a chainsaw bearing pocket on a husky case half (the pulley is even orange
I spun a bearing on my kioti ck-20 mower deck -- it's one of the greaseless idler pulleys.
I took the number off of it and it is 6303Z. The original bearing is GMB part # 6303Z and I found an SKF part #6303Z with the same specs (bore and outer diameter are identical so it will work) so I just ordered one.
Well -- the new bearing is missing a cover on one side -- any ideas why? I'm assuming if I run the new bearing w/o something covering the exposed side crap will get in there and ruin it?
Here's some pictures to make it completely clear -- first picture bearing on the left is new one, bearing on the right is old one, pulley you can see the pocket and snap ring to hold bearing in there (will need to heat pulley and cool bearing to get it in the pocket similar to a saw it is tight):
In this second picture below all I've done is flip over both bearings -- the old bearing is covered on both sides, the new one has this side exposed. I'm bummed -- I couldn't find the original bearing GMB brand anywhere and this mower deck hasn't been made for several years now -- it's the DMM-60 model from Kioti and is Italian made -- possibly by Del Marino. Any ideas on how I could get a GMB original bearing or any other ideas would be appreciated.
Sorry to booger the saw forum with this, but perhaps it could be moved to off topic area after a few of you guys have seen it.
Thanks guys -- I'm learning, remember I'm a desk jockey by trade but not afraid to wrench on saws and other mechanical things and I enjoy it and want to continue to learn!
