exSW
'Cause Thomas is a poopyhead
- 11:29 PM
- Dec 23, 2015
- United States
By that same token if you raise the piston by one mm do you increase the stroke?On some jugs it is a nightmare, it may even require building up the tunnel on the outside with GB Weld so that the proper size and shape can be achieved. Other jugs may only require a bit of 'blending' - if you have the right tools to do it.
If done properly, it is a superior way to get more time/area for the transfers. A two-stroke can only begin to 'inhale' a fresh charge when the transfers close. If you raise the transfers 1mm, you shortened the 'stroke' by 1mm.
Measure the distance from the transfers to TDC - that is the working stroke of the engine. Say that distance is 23mm, now raise the transfers 1mm and that distance decreases to 22mm. - The 'displacement' of the engine has been reduced by 4.5%.
