HELP! Anyone use CBN wheels for grinding chain?
davidwyby
Rural desert logging
8:54 AM
Extreme Southeast CA
What's the general consensus on who makes the best CBN wheel? What grit is the best all round grit? I've read the whole thread. To me is looks like what ever floats your boat and makes you happy. LOL!
@davidwyby still running the 300 grit? Or was it more of a pain than it was worth?
@huskihl still like the CBN wheel you have?
@Woodpecker still like the ones you have?
Just bought a grinder, so I'm looking at options.
300 too fine except for…fine finish grinds, never tested to see if there was value in it.
Their std wheel is hybrid/mixed grit and good. I can’t remember the brand but I probably mentioned it. That’s what I would get. *Baltic Abrasives
My coarse cheap wood turner’s wonders is awesome for fixing damage without heat, but maybe a rough edge isn’t durable?
Powerstroke Cowboy
9:54 AM
Montana
Thanks David. I think 🤔 it could.be fun to play around with a fine grind. I'd think it would cut a little better. Is it worth the time though? You want a couple grinders for sure though.
Thanks for the information. I'll have to look into all the different brands mentioned.
i would like to have a square one to try. i dont know if they make them though
mrxlh
I stayed late and finished!
10:54 AM
Dat Boot
I’m running the UF Sharp 80 grit CBN 3/16” and 1/8” wheels for sharpening, and the Baltic abrasive CBN fine grit (no number given) for rakers on my Super Jolly. Zero complaints and very nice results with any chain brand I have sharpened with them. I used Kevin’s last year at Denny’s and was hooked, especially the no dress CBN part.
av8or3
11:54 AM
Waleska,Ga.
Someone, in this thread I think, ordered a custom square cbn wheel.
I did and I used it today. I sent them a fresh, sharply dressed copy in blue and six months later the new wheel arrived.
Cowlitz River Rigging. $300 a copy.
The CBN wheel I used today was totally predictable, it cut just like the blue wheel and the angles are indeed the same, or at least so close I can’t tell any difference. I hate dressing wheels. It was nice to not have to today.
av8or3
11:54 AM
Waleska,Ga.
have you had it a while? if so have you had to have it re-done?
I’ve had it about a year but I don’t sharpen chains that often. I don’t see this wearing out though. Cutters are almost like butter up against the CBN. When I was using stone grinding wheels a lot of my attention was spent protecting the wheel. Now I can just concentrate on the cutter. The wheel feels feels very corse to me, but it leaves a sharp,polished surface. And I don’t have to dress the wheel. I like that.
av8or3
11:54 AM
Waleska,Ga.
Here’s the cutters I did yesterday.
I use the bottom edge of the wheel to lower the rakers after the cutters are ground.
In the close up cutter pic you can see the chrome that peels up as the blade is ground. It snaps off on contact with wood and doesn’t seem to be causing a problem, I just wish it would go away. lol.
