- 6:41 PM
- Dec 30, 2015
- Georgia
G56 won't hold together around 800 HP. The case starts flexing and you break shafts. The 5600 was stronger except the counter shaft. You could break it once and put a sleeve on it. They were holding around 1k HP sled pulling.
Only 92,000 miles on mine, bought new in '06. I just wish it was a longbed...
Welcome Sir !! Happy to see you hereRiff-raff here, present and accounted for. Mostly...![]()
I used to talk with Harry a lot. Back in the early 2000s they were one of the few shops around doing a lot of stuff and experimenting. If I really wanted to play I'd go 4Hi and 3rd or 4th gear boosted launch.![]()
Is it ok if hort wankers hang out here?
John
Keep an eye on the shifter boot! The red one is bad to split and allow the fluid to leak. They have a black replacement for the fix!http://www.ebay.com/ulk/itm/252199150738What I have in mine. View attachment 1466
Those appear to be the original body style . they are the ones the serious tuners want .He lives just up the road from PDR. I've got enough addictions, dont need anymore.
I've always left my trucks stock, air filter & exhaust is all I've done, except one I put a quadzilla chip on, didn't like it, so pulled it off and sold it.
I knew it was the pump and how you can crank it up ! My younger cousin only plays with CumminsHarry has his own business now Peak Diesel. I bought some after cooler boots from them. The first ten rotary pump won't put out near the power the inline pump does like in the picture with the hood up.
I don't care for the obnoxious loud and no power. I had a 24 valve with an HX 40 6 fin wheel and it was crazy loud at 40 lbs of boost. Louder than the S300 with the 64/71 set up on a 3rd gen. It would make enough boost to blow the valves back open though with stock Springs.
I work on a few they are loud for sureYou want loud one word, DETROIT!
Joe
