Anderson/Blackthorne M16A3 copy
FergusonTO35
4:42 PM
Boonesborough, KY
Still shooting the rifle and carbine and they work great. 100 yards is pretty much the max I can use open sights with any of my rifles. I think I need thinner front sight posts, the thick milspec ones aren't very precise. Neither of these guns have ever had any sort of malfunction, even with cheapo ammo and mags. Sure wish we could get some fast burning rifle powders around here. Loaded ammo is fairly easy to find, not cheap of course.
srb08
Doesn't play well with others
3:42 PM
Mid Mo
What rifle powders are you looking for?
FergusonTO35
4:42 PM
Boonesborough, KY
IMR/Hodgdon 4198, 3031, Reloader 7. I have a fair amount but always looking for more. My local shop is finally getting some powders back in so mebbe those will show up soon. They are almost back to normal stock on rifle and pistol bullets.
Muad
4:42 PM
Black Swamp
I switched to a thinner NM style front post, and saw marginal differences in my groups. The GI width post works fine, as it's all about sight picture. Unless of course the post is so wide you can't see your distant target, LOL!!
I may have a NM "thin" front sight post in the parts bin if ya need one. I tried some on a rifle I had built in anticipation of shooting at Camp Perry, and also in our local Service Rifle matches.
I'll take a look. I know I also have a NM carry handle sight setup, with the hooded rear aperture. Can't remember which "disc" is installed in it.
FergusonTO35
4:42 PM
Boonesborough, KY
Thanks bro, let me know if you have it. I have astigmatism, which makes things fuzzy when I try to focus on them. The standard front post is so prominent that the "fuzz" makes it difficult to judge where it is in relation to the target. A small bullseye that I can see with the naked eye gets lost when aiming at it, even when using a six o'clock hold.
Muad
4:42 PM
Black Swamp
I do have one in the bin. I'll measure it tomorrow and let you know the difference. I have a standard from a "F" marked FSB, two of the extended posts (longer threaded portion and slightly taller post for use in certain F or Non-F applications with an A3 upper), and one of the thinner posts for a match rifle.
I'll get some measurements and pics ASAP.
FergusonTO35
4:42 PM
Boonesborough, KY
Thanks! Both my rifles are the flattop with F marked front sight, far as I know they are nothing special.
Muad
4:42 PM
Black Swamp
OK, standard "GI" post seems to measure about 70 thousandths on my calipers. The "NM" post I have seems to be about 56 tapering to 58. Also, it's not "square" at the too, it has an incline machined into it. So, it looks like you'd need to have it aligned a specific way. Not sure if that would cause an elevation zero issue or not.
Pics.
Straight on as it's intended to be aligned:
Side shot of the incline I was speaking to:
Sorry they're sideways, they're proper orientation on my phone.
Muad
4:42 PM
Black Swamp
Where is the LOVE button? :0)
Nice examples. My favorite AR is my M4A1 clone with Colt 14.5" SOCOM (heavy) barrel and good ole GI irons. It's pin and welded, of course (not today ATF man). I love irons, but have scoped/RDS'd rifles also.
My eyes are still decent, so I'm good out to 500+ on echo silhouette targets.
FergusonTO35
4:42 PM
Boonesborough, KY
Pics.
Thats strange! Wonder if it was intended to be used with a specific front sight base?
Muad
4:42 PM
Black Swamp
Not that I'm aware of. NM FSBs are adjustable, versus your normal fixed, pinned FSB. That said, they're only adjustable for windage.
I'm guessing you get the zero as close as you can with the post in the proper position, and then you can adjust the drum on the rear sight to get it zeroed on 6/3.
Does that make sense?
FergusonTO35
4:42 PM
Boonesborough, KY
Yes, it does. I should probably just pick up a pack of thinner sights and just see which one works best.
SteveinUT
Have gun - will travel
2:42 PM
Southern Utah
One I built this past spring.
