All Things 288XP
11:28 PM
Sooooooo...If a 394 carb bolts up to the 288; could a 394 HD filter elbow be used on the stock 288 carb? Left field I know, just spit balling.
394 hd elbow is NLA but 395 hd elbow is same basic thing just have to drill/clearance holes out to fit larger carb bolts and bolt heads carefully. Not sure if it fits on a 288.
Toad22t
10:28 PM
Central Wisconsin
Given Mike isn't really a fan of the 288 he sure builds a mean one doesn't he. Talented guy
I've had Mike do a 7900 and a 385. I also have a 346ne done by him along with some of his chain's. His saws all run amazing and his chain's just plain out cut. He's a pretty damn good guy also.
XP_Slinger
They’re Just Saws
11:28 PM
Central NY
Had a bizarre failure on the 288 today. The flywheel nut loosened and the flywheel sheared the key. Not knowing what had happened after it stalled, I pulled the recoil rope and there was no resistance. I thought something real bad happened inside the motor. It's up and running again but I can't figure out why the hell it happened.
Should I put some loctite on the nut? Any body ever have this happen?
T.Roller
11:28 PM
Southeast, TN
You should still have the same resistance with or without a flywheel in it.
RIDE-RED 350r
11:28 PM
Blossvale NY
Not if the key is sheared the the nut is loose enough to allow the flywheel to spin freely on the crankshaft when you pull the starter rope. I haven't had that happen with a saw yet, but I've seen it on other small engines. Sounds like that's what happened in this case.
T.Roller
11:28 PM
Southeast, TN
Yeap you are right about that. I was thinking the crank turning over but if the flywheel ain't tight it wont. Carry on lol
XP_Slinger
They’re Just Saws
11:28 PM
Central NY
Yep Joe nailed it. Flywheel spinning freely on the crank. Made nice metal on metal scratching sounds. I about crapped my pants initially thinking my Saw had just completely grenaded in some way that killed compression.
