T.Roller
- 11:49 PM
- May 11, 2016
- Southeast, TN
394 hd elbow is NLA but 395 hd elbow is same basic thing just have to drill/clearance holes out to fit larger carb bolts and bolt heads carefully. Not sure if it fits on a 288.Sooooooo...If a 394 carb bolts up to the 288; could a 394 HD filter elbow be used on the stock 288 carb? Left field I know, just spit balling.
Whatever you're up to looks fun. Recently acquired builder?
That's a dang good price for eBay. I recently aquired all the parts I need to switch to high top thanks to mdavlee and Dale. If that weren't the case I'd be all over this. Thanks for posting bud.Ran across 288 Hi Top stuff on the bay.
http://www.ebay.com/itm/HUSQVARNA-288-288XP-CHAINSAW-TOP-HI-TOP-COVER-FOR-LARGE-AIR-FILTER-GOOD-USED-SH/162628140082?_trkparms=aid=888007&algo=DISC.MBE&ao=1&asc=45726&meid=8512fa1f286641c48ee7071328cbc49a&pid=100009&rk=1&rkt=1&sd=232444590788&_trksid=p2047675.c100009.m1982
http://www.ebay.com/itm/Husqvarna-OEM-Air-Filter-503551271-for-Chain-Saws-281-288-503-55-12-71/351768887631?_trkparms=aid=888007&algo=DISC.MBE&ao=1&asc=45561&meid=915a1eba6b3543bd8289080a6e2e38b3&pid=100009&rk=1&rkt=2&sd=162628140082&_trksid=p2047675.c100009.m1982
http://www.ebay.com/itm/NEW-OEM-HUSQVARNA-HEAVY-DUTY-AIR-FILTER-PART-NUMBER-503-55-12-71/192104342493?_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=45561&meid=e0b8a2277bb44ab196f6529d1832cebf&pid=100005&rk=5&rkt=6&sd=351768887631&_trksid=p2047675.c100005.m1851
One Mike Lee was doing for me. He got all the real work out of the way lolWhatever you're up to looks fun. Recently acquired builder?
Sounds like a good build threadOne Mike Lee was doing for me. He got all the real work out of the way lol
Lmao I wouldn't know any secrets when it comes to race saws lolSounds like a good build thread. Unless of course it involves race Saw trade secrets. Those carbs are huge
http://opeforum.com/threads/trollers-181.6457/page-4 I'll be updating shortlySounds like a good build thread. Unless of course it involves race Saw trade secrets. Those carbs are huge
Forgot all about that thread. Looking forward to the build and hearing your Saw tear it up.http://opeforum.com/threads/trollers-181.6457/page-4 I'll be updating shortly
Given Mike isn't really a fan of the 288 he sure builds a mean one doesn't he. Talented guy
I've had Mike do a 7900 and a 385. I also have a 346ne done by him along with some of his chain's. His saws all run amazing and his chain's just plain out cut. He's a pretty damn good guy also.
You should still have the same resistance with or without a flywheel in it.Had a bizarre failure on the 288 today. The flywheel nut loosened and the flywheel sheared the key. Not knowing what had happened after it stalled, I pulled the recoil rope and there was no resistance. I thought something real bad happened inside the motor. It's up and running again but I can't figure out why the hell it happened.
Should I put some loctite on the nut? Any body ever have this happen?
Yeap you are right about that. I was thinking the crank turning over but if the flywheel ain't tight it wont. Carry on lolNot if the key is sheared the the nut is loose enough to allow the flywheel to spin freely on the crankshaft when you pull the starter rope. I haven't had that happen with a saw yet, but I've seen it on other small engines. Sounds like that's what happened in this case.
