Sty57
- 2:02 PM
- Jan 6, 2016
- Land of Cheese & Beer
Depends on which one you get.Ah, I believe turbo blue is 116
Turbo blue make a few different fuels.
I left it in on mineI always wanted to try a RWJ4 with the divider led in for a better signal on maybe a 346 or 365. Seems the divider would let the Venturi only be half size to pull fuel
Try it....You might be surprisedI cannot get my needle to hold pressure. I will try something different next time. This one will never be used on a saw for sure.
With alcohol?I have tried carburetors with needles that wouldn't seal before and they are very troublesome. If you try to adjust to compensate for it the saw will run rich/lean/rich/lean...... At least that's what has happened to me.
