Aftermarket MS660 Performance
10:33 PM
4,500 RPMs is way different than 14,000, but the point about diminishing returns I'm sure is valid.
brshephard
Stihl saws, Husky women
8:33 PM
MT
I found this link, about compression and more heat generated, as well as knocking, not really sure if holds up to chainsaws. But it’s worth thinking /looking into. Maybe another reason why some chainsaws grenade
http://www.bridgestonemotorcycle.com/documents/higher_compression6.pdf
Good read.
I've learned from folks on here that these saws have pretty low compression ratios, like less than 10:1.
They also have pretty low specific output.
An MS660 is 92cc/8hp = 8.7cc to make 1 hp
My stock Skidoo snowmobile is 160hp/800cc = only 5cc to make 1 hp
That's how guys can get away with 200+ even in production falling saws.
Is 200+ better though? I'm not sure. Thats why I joined here, to try and learn the tricky design stuff.
brshephard
8:33 PM
MT
New jug came in today.
What numbers should I try?
Its at 97/128/82 stock
Here's some pictures:
brshephard
8:33 PM
MT
And the transfers:
The combustion chamber looks big compared to the farmertec
Wonkydonkey
Plastic member
3:33 AM
Sussex, UK.
I don’t know if you got a squish reading, but it’s a starting point weather you use any type of gasket, that’s if you don’t have a lathe. I can’t remember if said you did or not.;)
brshephard
8:33 PM
MT
Nice job! Chain looks money too.
Did you find more torque going with a shorter blowdown?
Fruecrue
certified hand catcher
10:33 PM
Alden NY
I didn’t mess around with blowdown so I can’t comment on any difference.
Pop up, timing, and port width were the big gains.
brshephard
8:33 PM
MT
I see, nice work.
I think I'm gonna go 101 as well.
