- 10:25 PM
- Apr 24, 2019
- Waleska,Ga.
The service manual says max off load engine speed is 8000 rpm. I set it to that on a warm saw and I get 6800 rpms in the cut. Saw cuts really slow at that speed. However....
if I tunes it to around 8000 rpms in the cut it cuts much faster and smoother.
I’ve also diagnosed an (intermittent) air leak on this saw one or both of the oil seals.
Seals are on order and saw runs steady if I start slow . If I piss rev it and drop it in the wood sometimes it will rev to 9200 in the cut ,stay there and just blast thru the log. I’ve leaked checked it, it leaks.
Once repaired , which is best way to tune it?
