Advice needed Stihl Hs76 hedge cutter carb
Martin
The new boy
4:54 AM
Essex, England
I'm after a little help from someone in the know. I have a stihl Hs76 single sided hedge cutter with a Walbro wt264 I think, it's playing up and not running right I have stripped, ultra sonic cleaned new diapham and gaskets but still not running right. I wondering if any zama Carbs will fit as these are a lot more readily available. Or will I have to still to Walbro? Thanks for the advice.
Homemade
11:54 PM
Wisconsin
Have you done a pressure and vac test? Could be a leaking gaskets or seals that is causing it to be hard to tune.
Fish
11:54 PM
Manton Ky.
What is the running problem.
Finding any replacement carb may be a challenge. the carbs from the FS72,74,76 should work.
Martin
The new boy
4:54 AM
Essex, England
I know that the hedge cutter has been sitting for about 2 years with fuel in so guessing it's blocked somewhere. When I undone the cap the smell was horrendous. I have just found a fs55 zama carb and it looks nearly the same so will try that tomura as it's a bit late now and I don't think neighbours will be to impressed.
Martin
The new boy
4:54 AM
Essex, England
The machine will run full speed for a while then when goes to tick over it nearly dies, won't pick up again and when it does it won't rev constant, up and down
Fish
11:54 PM
Manton Ky.
New fuel line?
Did you have the needle out when you cleaned the carb?
Did you hold the carb body up to a light while the needle was out and visibly check that passage?
Martin
The new boy
4:54 AM
Essex, England
Yes fitted new lines as old ones were rotted also fitted new plug, fuel filter and airfilter.
I stripped everything out of the carb even mesh gauses and replaced the lot with new.
I had my magnifying glass out to check all passage ways and all looked clear, but I guess it only takes a really small bit of crap to block somewhere
