Adding a 4th Saw
jeffkrib
7:10 PM
Sydney Aus
Suggestions???
You have a rock solid line up from 201 to 400, 15cc increments which is pretty much ideal.
How about a battery powered top handle at the bottom end. At the top end a 120cc saw. Where I see a gap is between the 400 and 390, 21cc increment.
Maybe get a Ms500, sell the 390 (or maybe not) and get a ported 395. That way you're more or less going up in 15cc increments.
I also currently have a 4 saw plan, 201, 550xp, 7900 and ported 661. My plan is to fill the gap between 550 and 7900 with a 400.
Member
4:10 AM
Suggestions???
572XP, it also cuts above its weight class and will do a lot of what your heavier 390XP is doing now. Will run along with a 500i so close but at a whole lot less cost to your wallet. Oils a long bar well. Will also start to correct the MS to XP imbalance you have going on currently. That and all the cool kids are getting them I hear.
Good luck, CAD's a real biotch.
mrxlh
I stayed late and finished!
4:10 AM
Dat Boot
Suggestions???
I can think about 5 different combination 5 saw plans. Knowing what you said about the wood you cut, and what the others have thrown out there. My big saw would be a 500i or 7900 ported. You have the 390, which I have one as well and have cut with it quite a bit, I prefer my 395 for it over the 390 for bucking or noodling. (Both stock saws, just MM on both) I would level across, dump the 390 and get a 7900 and have it ported.
If you just are looking to add a 5th saw, I’m going against the grain by saying one between the 261 and 400. A 357XP ported would be my choice.
I have the 66cc class saw covered fairly well, but have run Brad’s 400 ported and even though I don’t need another 66 cc class saw, It and the 462 ported are probably the last 2 saws I’ll add to my fleet.
ZERO
Simple Life
11:10 AM
Woods & Mountains
Steve glad to hear that.
You've done such an amazing job on the 372OE, I may have to skip this one. 🫣🫣🫣
5:10 AM
Saw brands or models there of is a Ford/Chevy thing .About like what brand and ratio of mix oil . Many times opinions are set in stone .Some times it does make for lively conversation though .I for one could not see paying $900 and up for a chainsaw to cut fire wood but it's really none of my business but it is amusing .
HumBurner
2:10 AM
Humboldt
$900 will barely get you a newish 70-80cc saw of Husqy or Stihl.
If you're not cutting in big wood with any frequency......okay, sure, no need to spend big for a big motor.
I didn't own anything bigger than a 60cc until I had a client who needed a dead 40"+ madrone cut and bucked. Once I got a 390, bigger wood just kept landing on my plate.
Might go a whole year without busting out the bigger saws. Might do multiple days back to back.
HumBurner
2:10 AM
Humboldt
Just buy a truckload of saws, run them all to see what you like best then buy multiples of your favourite, when that gets old start getting them ported.
I think I have 20? And I’m pretty sure that’s still rookie numbers
I pretty much went this route with small saws. It has pros and cons. But now I know what I like and why.
mrxlh
4:10 AM
Dat Boot
$900 won’t get you a newish 70-80cc Husky or Stihl. It wont even get you a new Makita 7900, I think some posters are still living like their buying saws 6 years ago. I brought my Dad with me to a really well stocked Stihl dealer, he was shocked at the prices. He thought that anyone who paid more than $500 for a chainsaw was a fool.
From an investment standpoint, larger CC saws seem to hold their value better, as they are typically not used daily and worn out easily. One thing I’ve learned since going to GTG’s and hanging out in general in the chainsaw world. Only run the largest saw you need to for the job at hand. Your body will thank you later. I’m average height, and build, I love the 66-70cc class saws, they don’t fatigue me easily and you can cut fairly large wood with them easily.
Ported saws is where it starts to get interesting, different chain styles, bar weights/lengths all make a users experience different. If I’m in smaller diameter or softwood, I go for my 346XP with a 24” light bar, full skip chain. I actually used it the most at Walt’s GTG last year and loved it. Walt did have some real big stuff that the 7900 and 395 were fun to cut and noodle up to manageable/splitable sized pieces, but the 346 was by far the funnest to run fatigue wise.
HumBurner
2:10 AM
Humboldt
