About to take bfh to husky 242
weedkilla
11:46 AM
lobethal, South oz
im with stump you have a weak clutch spring or worn out drum
My first thoughts too.
New clutch spring and new bearing before I got confused and asked you guys.
Doubt it's the drum - a spur drum just can't be that old.
10:16 PM
Brake band might be bad (out of round), torquing the drum on an angle. Or maybe your new drum bearing isn't good
Member
9:16 PM
The only thing I can think of is to somehow replicate the movement and direction of pull of the chain brake with the chain brake off. That Gremlin can't hide forever.
CR888
12:16 PM
Could the intake rubber boot get lifted when the brake is pressed and leak causing the stall? Just guessing, this is a secret mystery chainsaw 242.
Mattyo
Youtube speciawist
10:16 PM
Farmington, CT
take the chain off .... see if it does it....
have to start eliminating variables
i would swap the clutch drum next
weedkilla
11:46 AM
lobethal, South oz
Hmmm. It's an instant stall - something along those lines makes a bit of sense. I made sure no wires were getting pinched/causing a short.
Gunn
Yay sawz
9:16 PM
Plover wi
What happens if you fatten up the low side and then trip the brake?
10:16 PM
If it's the intake being stretched, it'll still do it with the clutch and drum removed. Take them both off and install the cover and trip the brake.
10:16 PM
if you take the clutch and drum off and try to use brake you accomplish nothing right ?
VinceGU05
one day when i grow up...
10:16 PM
S.E Australia
Same. Tried every variation of tune imagineable.
even having it idling on 3200 rpm it stalls instant? can you flex the saw between the tank and case ( like when ya hit the brake) to see if its the intake air leak. otherwise i would try new seals and maybe crank bearings.
Mattyo
Youtube speciawist
10:16 PM
Farmington, CT
There is too much play somewhere in that clutch drum. So tripping the brake moves it far enough so that it grabs the clutch.
Wrong needle...missing needle....or....how about a worn crankshaft. ...that would do it. If there is too much play in the needle bearing because of a worn shaft that might allow the drum to move eccentrically.
