A dummy and the Stihl ms441c
maulhead
8:13 PM
Home
OP I know you said you found a coil, I saw your thread the other day just did not get time to reply before you marked it found.
Anywho, I recently picked up six 441 parts saws, some are MT some are regular carb, in case you find yourself in need of other parts.......
Maintenance Chief
10:13 PM
South Carolina
Im looking for an Arctic M-tronic flywheel, if you have one?
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Coil showed up off ebay.
I don't think it's correct. I'm coming up with fitting a 362c only?
Can anyone confirm this?
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
I know the wiring is different than what's in the carb box and based off my memory the coil wire seems too short.
If it's just wiring, I can splice that no problem.
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Yes you are correct, it is for a MS 362 C. If your serial no. is before 181 222 948 you need the carburetor, control unit set 1138 007 1008 to fit the older version.
Thank you. I will check out the serial number tonight.
9:13 PM
