881 vs 661
atimmons101
4:42 AM
Strathroy, ON
Looking to get into some chainsaw milling as buying any kind of hardwood these days costs a fortune! I already have a 462 and a ported 500i but I’m looking for something with a little more grunt for big hardwood and the occasional milling. 661 feels like it would be just a small step up from the 500 whereas the 881 gives me a whole other class of saw to use on exclusively big wood and milling.
Thoughts?
Maintenance Chief
4:42 AM
South Carolina
I'm not sure how much milling to other stuff you'll get into but I've had an old 088 stihl for huge stuff for a few years and it really is in a class of it's own at 122cc.
I did build and aftermarket 090 and ported it myself for cheap and have run a 72" bar on it with no problem. Obviously buying a new factory saw doesn't require you have to know how to tune anything ( which is nice) but an aftermarket " once in a while saw" is nice to save some $$$.
Bill G
3:42 AM
I do not use a saw to mill with, I use saws to cut trees. I would imagine milling being very hard on a saw but never done so. Had you posted several months ago I had some new 881 saws to sell but they are gone. I do have some new 661's. If you want a real powerhouse I have a ported 084.
59billy
3:42 AM
MS
Having used a 660 for milling, if I had to do it again, id go for an 880/881/084 -- especially the MMWS 084 I assume you're talking about.
singinwoodwackr
2:42 AM
moon
For what you describe, 661, ported would be better and Stihl cheaper than an 881.
About a 10# difference in weight, lol
I can run a 50” on my ported 661 with modded oiler…just can’t pick it up anymore 🤣. The 42 is probably my limit now.
Speed contest? No comparison…a ported 661 will blow a 881 away, imo.
atimmons101
4:42 AM
Strathroy, ON
But what about a ported 881? I don’t know. I’m just trying to sus out the whole scenario. Right now I don’t care about weight an cost isn’t an issue in my mind if I make the right choice the first time around.
singinwoodwackr
2:42 AM
moon
If you like 25# saws :p
mainer_in_ak
12:42 AM
Interior Alaska
Very simple here, but its a little more difficult if yer head is too far up stihl's aszhole: The 881 is not a milling saw. Not even close. Porting will only polish a turd.
Stingy garbage oiler. The plastic oiler strips out in the cold as well.
The vibrations are severe.
Being strato, they get extremely hot toward the end of a 16 ft rip.
Multiple saw porters on here build 3120's for milling. They have a better oiler and most porters will set u up with an adjustable high jet.
Then there's pav and his dreamy CS 1201 milling build with pto-side roller bearing and unlimited rpms. A saw that will over oil a 42" bar and a manual oiler that easily oils my 84" bar.
Torque is still there as low as 6000 rpms. The crankshaft and connecting rod are larger than an 090. Lotta heavy metal chugging along.
59billy
3:42 AM
MS
Now im glad I cheaped out and bought a 660 instead of an 880!
Bill G
3:42 AM
All joking aside as nice as the 084 is I will say in my opinion it would not be a wise choice for milling. I want to stress I am not into chainsaw milling but I would imagine it to be quite tough on a saw and you would want a saw that you can easily get replacement parts for. I will assure anyone that an 084 is not an easy saw to get parts for.
59billy
3:42 AM
MS
I sold the 881's for $1900 and 661's for $1475
I paid $1025 for my 660 in 2007. I don't remember how much the 880s were, but it seemed like a lot.
In retrospect, the 660 is a great felling saw, so it worked out for me. I'm thinking about sending it down the road before long, because my back prefers those cute little 50cc saws.
