661 Stroker
9:20 PM
The limited coil on a 372/390 starts to advance around 3200-3300rpm and retards at idle to make starting easier from what I have seen. It’s a pretty abrupt change and if you have the idle set too high it makes the idle wonky as it goes in and out of advance. Not sure what stihl coils do or if the advance works the same.
I always thought that was the A/C kicking on and off...
Wolverine
dilligaf
9:20 PM
I raffed!
Hmm, so that explains that. :thumbsup: The HU365sp can be a bear to tune and I’ve experienced said wonk.
Bigmac
6:20 PM
Oregon
Interesting, all of my cr250 ignitions retard at high rpmC4869D3F-7300-4556-9F8F-778982E15552.jpeg
I have been seeing gains in high rpm hp an torque with less timing above 9k on my alky banshee, I gained 5hp above 9k and gained over-rev when I pulled 5°, I also lost power under 9k, I need a programmable cdi to get the best of both worlds. That was on a dyno, I know it’s not a saw but it is changing my thinking about two stroke timing. My Trx250r’s gain power with the cr250 ignition, and the cr ignition has less timing everywhere than the stock ignition, again showing less timing with rpms is a good thing, at least in my bike applications
Lightning Performance
9:20 PM
East of Philly
Interesting, all of my cr250 ignitions retard at high rpmView attachment 198534
Good combustion chambers tend to need less lead on the ignition timing. That generally applies on most liquid fueled engines. Gas might want even less than alky up above 6k
Bigmac
6:20 PM
Oregon
I agree, my testing and research has shown me that a fair amount of initial timing is helpful to get the motor on the pipe, and then a gradual reduction in timing with an even bigger reduction at peak power will extend the power longer. That’s reed valved piped motors
