jmester
- 10:58 PM
- Aug 28, 2016
- MD
Read in another post here that there is a pin on the oil pump that can driven in or removed so the oil pump control bolt will go another 1/4 turn. Thought I would post some pics of the said pin and location. I pulled my pin so I could always put it back in if need be. The pin boss is deep enough to drive it in flush with the pump. If you decide to drive it in you can use a punch to drive with out taking the pump off.
