592xp coil replacement
Jake Dykstra
6:01 AM
NW Washington
Does anyone know if replacing the coil/plug wire requires anything more than just a swap? Wondering if it needs to be plugged in at dealer for any reason.
Thanks
redneckhillbilly
7:01 AM
NW MT
I believe you can order one thats already programmed if you provide the carb # when ordering, if not than the coil needs to be paired to the carb at the dealership.
this is just 2nd info I have heard, I have no experience with replacing or ordering a coil for a 5-series husqvarna.
EFSM
8:01 AM
Extreme southern IL
I have replaced only one ignition coil on a 500 series Husqvarna and that was a 550. I had no issues with software/communication between the carburetor and coil.
9:01 AM
All 592s are autotune 3 so I don’t believe there’s a need to have anything synchronized. Always heard the only time you needed to do that is if you were replacing a coil or carburetor that weren’t originally used together. I’ve installed new 572 and used 562 coils and never had to have anything paired
Jake Dykstra
6:01 AM
NW Washington
Awesome! Thanks fellas.
My dumbazz pinched the plug wire against the flywheel when putting the starter cover back on.🤦
emanuel
4:01 PM
Ro
There’s no way this is real, it would be a massive minus for Husqvarna… For Stihl mtronic or fuel injection any part can be changed without doing anything else.
redneckhillbilly
7:01 AM
NW MT
was that your experience when replacing a Husqvarna Auto Tune coil? or is your statement pulled out of thin air?
fdhamlin
6:01 AM
Canada
I replaced my 562 coil with one from a 560. No problem. It will need the same carb on 562 as communication frequency change from EL44 to EL46.
So likely not an issue with 592.
9:01 AM
I guess I haven’t tried in a 5 series, but can’t you just replace the wire? In previous models you could twist the wire out and install a new one, but I know there are coils with the wire epoxied in place
singinwoodwackr
7:01 AM
moon
Jake Dykstra
6:01 AM
NW Washington
Seems epoxy in place. Haven't dug into it to deep. The conductor is fine so I just taped it up. I think I'll do a more permanent repair on the wire for the time being. Saw is new and I may sell now that its ported up and making good power and didnt want to sell with taped up wire.
emanuel
4:01 PM
Ro
Only husky autotune coil I replaced was an 2018 made 572xp which ran after that. I have no idea if their latest autotune iteration is anti-repair or not. I sure hope its just swap and go.
