572 updates
ferris
6:52 PM
Germany
Interesting video from the Austrian lumberjack fellow using the 500i and 572 with a comparison at the end. He used a 462 for a while as well. He liked the weight of the 462 a lot, and liked the 500i as well, but in this case his preference is for the 572. He's been using it for well over a year at this point.
He is a husky lover.
He is looking for strange things out of the stihl that je don’t like.
Example:
if he cuts at head height, he can better catch a kickback with the 572 because it's heavier. that's why the 572 is better.
In my opinion: If I have to lift the saw more often so high I would be glad if the saw is lighter.
MG2186
12:52 PM
Summer,IA
Example:
Sounds to me like you’re a Stihl lover and you just didn’t like that he preferred the 572......
1:52 PM
I think in the end... the stihl lovers will buy a stihl and the husky a husky... regardless of the paper specs. The husky is heavier because it has larger main bearings and beefed up bottom end. Simple as that. What conclusions you draw from that is up to you, but I dont care to pack a little more weight if its gonna last and be around for a good while.
Benjo
Some Guy
1:52 PM
New England
That is also Right, but 1kg difference is alot
Is it really 1kg?
I've seen MustangMike's weight on his 462 showing Stihl's advertised 6kg weight is accurate, but I haven't seen a dry weight of a 572 showing Husqvarna's advertised 6.6kg stat isn't accurate.
There's probably one somewhere on the forum, but I haven't seen it yet.
qurotro
Cookie Cutter
12:52 PM
Ar
You're indicating that the 462 wont last as long as the 572? Thats gonna hurt somebody...
Just sayin....
Spike60
1:52 PM
Ulster County, NY
Exactly, and I've been saying that all along. Most guys are quite loyal to one brand or the other and there is very little cross over. Certainly not due to any of the specs that get a lot of play here. I would never buy the Stihl, any more than Mike or Jeff would buy the Husky. It doesn't mean anything, and should not be taken as a slight by anyone. We have our favorites, they work and we're happy with them.
1:52 PM
I would also not be surprised if folks looking to run/balance longer bars gravitate toward the 572 and those running 20/24" bars gravitate to the lighter 462.
So, even though they are the same displacement, they seem designed for 2 different markets. At least, that is my take.
I really almost bought a 562 … but I had so many Stihl mount bars it just didn't make sense. Water under the bridge.
00wyk
5:52 PM
Ireland
I like turtles.
00wyk
5:52 PM
Ireland
I run a Stihl bar on my 288xp and 572! ;)
pro94lt
12:52 PM
South
Many will have both and run the bars best suited for the saw... I definitely will. But one thing I’ve learned is don’t take the forums word on it... you’ve got to try it for yourself and decide...
GCJenks204
"Special Buns"
12:52 PM
Winnipeg, MB
Now that I have a reasonable relationship with a local dealer I would seriously consider trying another new Husky.
If for no other reason than a serious dislike for STIHL Corporate.
Truth be told I already open both a K095 and D009 mount saw, I just haven’t held or run either of them.
1:52 PM
I’m sorta a husky guy... but the stihl forestry helmet is the only one out of several I’ve tried that doesn’t interfere with a hearing aid/implant as bad as the others.
12:52 PM
@Homelite410 bar adapter can fix that
