562xp Build... ignition/carb question
Brown8417
5:19 PM
Nova Scotia
I have a brand new 2021 case with cylinder and piston that i am building. I have a few questions to make sure I get it rights the first trip.
1. With the newer 55 carb what ignition/coil should I be using? Will a 70-01 work?
2. Are there any parts that are specific to the newer model? Top cover either hole, short fuel line... what about the fuel tank assembly, will one from a older 562 work?
Thanks in advance
Spike60
4:19 PM
Ulster County, NY
Carb will work with that coil. Just need to program the carb to whatever coil is being used. The only coil that cannot be used is the first one that operates on 14mhz. All the new stuff uses 8mhz. That first coil is the one that only has the white plug for the AT module/CST.
Fuel tank is the same throughout the model run. Will need the shorter fuel line, or just snip a 1/4 inch off the old one.
