CTtreeman
Active OPE Member
- 4:24 AM
- Jul 4, 2024
- Connecticut
Hi fellas, I just came across this forum through looking at different saw issues and it came up. After exploring the site I find it to be a wealth of good information and people.
I bought a new t540xp mark 3 almost a month ago took it home, filled it up and fired it up.
It was difficult to start but finally ran. I let it warm up at idle and then reved it up under partial load with the tip in a log to set auto tune as instructed by my dealer and in accordance with a video I found from husqvarna on youtube. The saw appeared to tune itself and then bogged down. I waited for it to pick back up and nothing. I let off throttle and the saw died. I looked and it had smoke coming out from around the starter cord area and smelled like burnt electrical parts or wires. The saw did not restart when I pulled it a couple times.
I brought it to my dealer soon as I could the following week and dropped it off. After a week I called to check and nothing. A week later I checked again and was told that the tech determined there was a hole in the block somewhere and the airleak burnt up the saw and it had scoring on the piston. The tech wrote customer did not cause this. I was told husqvarna wanted them to fully disassemble the saw and do more investigations and the tech didn't want to because he deemed it a waste of time with more possible parts and time than the saw was worth.
Another week goes by and I am told they are waiting to hear back from Husqvarna. Now I get a call this week and am told the warranty was denied. There was no compression. Then the tech sprayed soap in the saw and got 80 psi. Then the tech wrote bad gas. Husky denied warranty claim.
I came home and poured gas from the same container in another saw, ran it for several minutes and it worked fine didn't blow up. If the gas was old my thoughts would be that it wouldn't run properly and have trouble starting, not run at all or cut out. They seem to be saying I ran it with straight gas which I did not. I use a synthetic 2 cycle with fuel stabalizer mixed 50 to 1 in all my saws. Four other saws have used the same batch of mix and are fine with no issues. One other husky and three echos.
Their statement is quite insulting really. I chat messaged husky because you cannot call them and the guy called me back hours after he said he would so I couldn't pick up. Maybe I can get somewhere with them and maybe not.
From my knowledge an air leak in the lower end or seals on the crank could cause engine failure in a couple minutes. Even if it was run with straight gas the saw would probably still start and run again and have some compression. (Which it was not run with straight gas). If my oil to fuel mix was low (which it is not) it could still take extended use to cause total engine failure like I see here. This saw ran for a total of about 3 minutes or so.
Any thoughts on this besides don't buy another one? So you think I can escelate this with husky? What would you tell your dealer when you go to pick it up? Btw they are going to want about $120 when I come to pick it up.
