Funky sawman
Pony Power
- 12:22 AM
- Feb 10, 2017
- North idaho
Whats she doing with a 500 crank? Stole it from her ex probablyIt is a female Lindsay McClellan
Made contact with her. She said she would ship. I responded that I would send Goods& Services paypal and never heard another peep!Whats she doing with a 500 crank? Stole it from her ex probably![]()
The greatest saw made has failures, hard to believe……Im currently in the process of rebuilding 17 ms500i's, Many of them with broken cases, if i come up with an extra crank i will let you know
Heck, if he doesn’t want it, I’ll take it, lol
Yea, im not impressed with the new stihls, especially the 462 and 500. The cases are so thin that they bust out easilyThe greatest saw made has failures, hard to believe……
He probably just got done with 35 562’s though, soThe greatest saw made has failures, hard to believe……
True. I do not have FB I use my wifes for marketplaceI have no clue but sometimes a guy doesn’t have FB but his wife or GF does. Craigs list it all but dead and marketplace is enormous. Who knows…
Actually, its been the hundred thousand 572's that have lost crank bearings that haunt me the mostHe probably just got done with 35 562’s though, so![]()
It pulled together just fine but turning it over by hand it would not turn free and I have not yet put the seals I knew something wasn't right I tapped it on both sides trying to Center and free to no availIn this particular case I’m not sure, but it’s very common for the crankweights on the lobes to not be lined up perfectly. If you look though old threads here you’ll notice it.
If the lobe rotated the amount that the lobes aren’t lined up by, I’d venture to say that you wouldn’t even be able to assemble the cases.
Again, I’m not sure on the 500i, but many models have assymetric crank lobes.
Did you inspect the entire large side bearing?
Something certainly wrong with the sitch. Uncommon to see rust on a connecting rod.
Do you have a good-sized brass hammer that you can give it a good whack with? Using a punch and a hammer, you're likely not getting enough force to center the crank.It pulled together just fine but turning it over by hand it would not turn free and I have not yet put the seals I knew something wasn't right I tapped it on both sides trying to Center and free to no avail
I do have a brass hammerDo you have a good-sized brass hammer that you can give it a good whack with? Using a punch and a hammer, you're likely not getting enough force to center the crank.
