488 on the bench
Sam_choq
2:05 PM
Canada Québec
My budy tell to me is 488 come to run bad ,
so i crank it ,*f-word a lot compression for a bad runner
i check with gauge 190..... not supose to be has high like this for a 488 .
Why ? because a lot of carbon !
i open the hole with finger....
Sam_choq
2:05 PM
Canada Québec
I got some time for play with it and some olds cylinder .
Stock number is 102exh 122 transfer 70 intake
with 0.040 squish normal compression is arround 150 160
inside look
ring pin
cant go to wide and cant drop to much
2 ring go in the intake
20170319_185713.jpg 43mm piston..
Sam_choq
2:05 PM
Canada Québec
Wich way would you go with it pro grinder ?
I cant drop much than a deleated gasket because of the piston skirt.
Anyone have long term succes with welding and machining on the top of the piston? I think piston is not 100% aluminium ?
I know it can be weld but probably not the same heat resistance .
Four Paws
Chrome won't get you home
12:05 PM
ID
Cool project!
These saws are built really well. You can drop the jug plenty to get compression up - the chamber is small.
Focus on the basics - get muffler opened up, raise compression, port shapes, work the intake as much as possible. Looking at your tach it appears you got it figured out.
Site sponsor @fordf150 should be able to get you a new OEM piston and cylinder.
Sam_choq
2:05 PM
Canada Québec
Cool project!
thank you but i have find new oem piston .
yes i know is not a safe rpm but it limb with a big smile in the face like that , and still alive ....it is for play but still look like it can work hard and realy good on gazz
Sam_choq
2:05 PM
Canada Québec
Don't grind too much :grazy:
Angelr
8:05 PM
Galicia España
The pistons shindaiwa, which marketed echo, are priced at oem here in Europe
Angelr
8:05 PM
Galicia España
It works poorly the translator, I wanted to say that it is an original economic replacement
