461R AV mounts
PA Dan
8:58 PM
White Oak PA
They will have part numbers on them. Compare the numbers to a IPL to see which ones you have. There will be three listed for each. I believe the middle is the standard. Of your feeling vibes i bet you have a AV that has failed?
Catbuster
Roadbuilder Extraordinaire
8:58 PM
Lou, KY
She’s vibey
How do I tell which mounts I have and where to get softer if that’s an option?
Thanks
Blue are the stiffer mounts vs black for the softer mounts.
If one is torn it’ll both feel soft and vibrate like a MF.
Which handle is vibrating your hands more than you’d like?
davidwyby
Rural desert logging
5:58 PM
Extreme Southeast CA
If one is torn it’s both feel soft and vibrate like an MF.
Kinda bof but I think mostly the tank, and that blue one is up there on top by it. Now to figure out corresponding part numbers to colors and where to buy…no real stihl saw dealer here.
It feels like a 266, not shot mounts.
PA Dan
8:58 PM
White Oak PA
Tell me what part numbers you want. I just bought new ones for my 660 build and have a set for my 064 build. I can get them for you and if they are the same as the 1122's I have them here.
Catbuster
8:58 PM
Lou, KY
I was at the firehouse earlier (we run 1128, half-wrap Stihls exclusively on our engines minus the 460 R vent saw). They’re mostly intact-the 044s have a faded maroon (now almost tan) buffer for the upper rear handle mount, as does a 440 we bought in 2001. My first 046 (that I know was original) had a maroon one that faded over time. The 460 we bought in 2012 has a black one.
Checking some records, the last I ordered was 1128 790 9908 for an 046, I received 1128 790 9909, and it is black.
I would think 9909 has superseded that part or be different solely because it’s on the 461. A few of the 461 part numbers for parts that are common with the other 1128s are one number off, presumably because they stopped production of the 460, or maybe to track parts sales. I don’t know.
I’d order 1128 790 9909, that’s a safe bet.
The 9905 should be an 1122 series part for an 064/066/650/660.
davidwyby
5:58 PM
So in the footnotes, 1 is the regular run of the mill 461 presumably softer mounts. Diagram Part number 6, the lower mounts has 9904 for the 461 and 461R so presumably it’s the same for both.
Upper mount 9909 is the only one for 1 in the footnotes, the std 461, so I ordered one.
Here is mine…not really P/N but it does say R. I’m tempted to start drilling little holes in it. 😆
davidwyby
5:58 PM
The black can easily be mushed by thumb. The blue is basically immovable. Saw is floppier now, still a little vibe just revving it, but I like it better. Maybe the other mounts could be changed to softer as well but I think that would be too floppy.
Having to pull the plug to pull the top cover is
Dumb
