Stihl Potlicker
ok. does this saw have carb limiters by chance?It is inside the carb plate. Controls the needle valve inlet. Open too much, floods, open too little, runs lean.
ok thanksTurn the low jet in 1/8 turn and try starting. If it still has a problem turn it another 1/8 turn and try again.
Ok sounds good, and only when cold. Once hot is it staring poorly too? Just to be clear you don’t use the choke once hot. Are you using the decomp only on choke, or every time you pull it over? Dose it still have the limiter caps, and how many turns out is each screw set at?yes brand new. my starting procedure, 1) push in decomp, 2) put in full choke, 3) pull cord 2x(it will pop) 4) move to half choke and it floods
guess i will be yanking them outYes it has limiter caps
yes still has limiter caps, no i dont use choke once hot. and use decomp every time. and she will start once sh is warmed upOk sounds good, and only when cold. Once hot is it staring poorly too? Just to be clear you don’t use the choke once hot. Are you using the decomp only on choke, or every time you pull it over? Dose it still have the limiter caps, and how many turns out is each screw set at?
How well does it fire up without using the decomp?
Like it’s sposed to.
Dang, that must be nice. All my stuff works like it's opposed to..... opposed to working.
Haha! Call me a sissy on my 125!!! Drop starting that a have it stop and shake a 50” bar with using the decomp is sissy button worthy! My base gasket delete 461 pops the decomp every pull and will stop on a drop start even with the decomp, every once in s while!! LolWhat's a decomp????? LOL
Sissy button
Sissy button
I know, but sill!! I wish my 2100 had a sissy bottom! I put a stihl d-handle and that helped but there are times when it would be nice!Very true I was just funnin you guys. Lol
