Jason628
- 11:24 PM
- Nov 21, 2020
- Washington
So... I haven't messed around with many of these huskys but, I got handed a rancher 455 and got told to fix it. Saw idles well but when you chop the throttle it bogs. Owner tried putting a different carb on it and same issue. It has the EPA adjustment locks so the high and low will only move about 1/2 a turn. I turned the high out as far as I could and it runs a little better but, high rpm it kinda hunts up and down and will not completely ring out. Compression is around 120psi... which isn't great. I'm not sure what these usually run... 150? Any input would be appreciated. I'm bout ready to tell him it's a lost cause and needs rebuilt.
