440 case decked?
Ronie
1:00 PM
NC
This is a first for me, I put my crankcase together and bolted down the cylinder and it's a head slapper. Then I tried another cylinder that hasn't been cut and it's also a head slapper, even with a gasket. What do y'all think?
Ronie
1:00 PM
NC
It has to be the case, I can't think of any other reason.
Intoxsawcated
10:00 AM
Idaho
Looks like it's the case based on the quick search through fleabay.
Sent from my SM-S515DL using Tapatalk
jk14
1:00 PM
Glenside Pa.
Piston compression height?
Ronie
1:00 PM
NC
I'm just going to make a thick aluminum gasket to get the cylinder up where it needs to be.
Ronie
1:00 PM
NC
Why not cut the squish band and get the compression?
I've already cut .040 out of the squish band and I don't want to raise the compression anymore, I used different case when I was setting the squish.
Ronie
1:00 PM
NC
All is good, I made a .060 aluminum gasket, it's a little thick but it's all I had, and I'll take a little off the base and get the squish right. Squish is .046 with the .060 gasket.
1:00 PM
There’s an .034-.040 paper OEM gasket for the 044. It’s green. Came on the saws sold in areas of the world where the fuel is bad to intentionally lower compression.
I use it on hybrid builds with 272 slugs.
It does look like your case was decked, hopefully properly.
Ronie
1:00 PM
NC
Thanks for the info, It looks like around .045 was taken off the case and I made a spacer out of some aluminum.
