3D printer
Mig_Selv
8:31 PM
The Arctic Circle
You misunderstood me.
What I said was, that you have to machine the 3D printed parts, so they're round and square.
If it's just those two parts you need, I'd simply make a 3D drawing, as it's a very simple shape.
Bill G
1:31 PM
I have not found anyone that wants to tackle it. They just tell me to talk with someone else.
Shane¹
2:31 PM
Kentucky
I bet the guy that did my cover would try to tackle it. He also works at a machine shop so if they need to machine it too he could probably make it happen. How many would you like to make?
Bill G
1:31 PM
Of course with everything that depends on price and the price depends on how many. It is a great case of " which came first the chicken or the egg" I would need 5-10 of each and prefer the higher amount.
Shane¹
2:31 PM
Kentucky
Honestly making the program is going to be where the most money is then easy from there so I would say the more you make the cheaper each piece would get send me some more detailed pictures and I will run it by him and see if he can give me an idea on how hard/ how much he thinks it will cost
Bill G
1:31 PM
I just sent them
SimonHS
7:31 PM
Yorkshire, England
How much stress are those parts under? If they are light duty you can 3D print them directly in metal. No need to mould and cast.
Mig_Selv
8:31 PM
The Arctic Circle
You can print high stress parts in metal, it's just a matter of the price.
If you make a 3D drawing, you can get offers from 3D printing companies. It may be the cheapest solution.
Bill G
1:31 PM
I cannot make a 3D drawing.
SimonHS
7:31 PM
Yorkshire, England
I just sketched your parts in 3D, using dimensions that I guessed from your photos. Send the proper dimensions to me and I will adjust the models, add the fillets and do some test prints.
Are the relationships of the rectangular slot and double square hole to the gear teeth important?
SimonHS
7:31 PM
Yorkshire, England
How do you do that? From a picture to this sketch?
It's an easy shape. The basic form is a top hat. I extruded a disc and cylinder and joined them. But it can be made by rotating an L shaped pline through 360 degrees. Then I extruded one gear tooth and copied it six times at equal points on the model. Then using that basic shape I did an extruded rectangular cut for one part and an extruded double square cut for the other part.
Bill G
1:31 PM
View attachment 444491View attachment 444492
WOW!!!
THANK YOU!
Let me do some measurements.
I wish you were on this side of the big pond or I would send you the originals. I sent parts to AUS years ago and they ended up in France.
SimonHS
7:31 PM
Yorkshire, England
WOW!!!
THANK YOU!
Any dimensions yet Bill? I'm back at work on Monday. Will have less time to do other things.
SimonHS
7:31 PM
Yorkshire, England
