395 OEM piston pin circlip issue
EFSM
8:53 AM
Extreme southern IL
Pardon my greasy fingers, but has anyone else had trouble with the circlips with OEM 395 pistons? I received a new piston today and found that the clip was next thing to loose after being installed into the piston, easily spun with a fingernail. I ended up using the clips from the old piston, which fit properly and are obviously larger.
old clip upper, new clip lower
Woodwackr
7:53 AM
ID
Looks like they included the wrong size in the kit.
Wolf Creek has the Stihl type.
Woodwackr
7:53 AM
ID
I wasn't very clear, but we are a Husqvarna parts/service dealer, so this was an OEM husqvarna piston.
I got that. Somebody, somewhere, likely at the factory… screwed up. It happens.
3:53 PM
Wire thickness looks slightly thinner OD and the loop opposite the ear seems quite shorter.
Considering my limited experience with changes in OEM Dolmar parts over the past 2 decades or so I would guess they changed the clips supplier without double & triple checking fitment.
Makita did this with numerous Dolmar parts.
Good thing You noticed that!
Report it to Husqvarna?
