390xpg Value?
MR_T
7:58 PM
Wisconsin
What is the value of a 390XPG used? Supposedly "like new"
Trying to find a saw for a backup saw and obviously winter use when the hands are cold..
Thanks
hacskaroly
2100 Fanclub Member
5:58 PM
Northern Idaho, Ehh
This is all I got for a picture..
If you can communicate with the seller, see if they will send you a picture of the piston (remove the muffler and look through the exhaust). The saw can look pretty on the outside and be all sorts of FUBAR on the inside.
MR_T
7:58 PM
Wisconsin
If you do not mind the electronics you can get a new 592XPG from Bruce
I've seen that. I'd rather stick with an old-school adjustable carb. I did locate a member on FB that builds 585s into "XPG." He does ask enough for them, and I get it; the saw is around 1050, then I don't know, 250 or 300 in parts? So it adds up.
Bill G
7:58 PM
Please PM a link to the FB member
whitesnake
8:58 PM
NY
That’s neat. Always wondered about that. Or a 585 carb set up on a 592xpg. But like you said the money adds up fast.
MR_T
7:58 PM
Wisconsin
I want to say most of the parts are the same. I was told you can throw a 592 top end on a 585, so there's that. I thought about doing all that, but then you're spending maybe 1700 or 1800 for a 592XPG carb saw.
I thought I saw somewhere someone did throw a 585 carb on a 592?? I don't remember if the flywheel or coil had to be changed. Maybe just the coil? All I remember was seeing a video of this guy drilling into the side of the case for the three carb screws. It was either on Facebook or YouTube.
whitesnake
8:58 PM
NY
Both are probably possible. But it would be a labor of love. Definitely doesn’t make much financial sense.
