Iron.and.bark
- 8:23 AM
- Feb 26, 2016
- Australia
Which colour of coil is the desirable one on these saws?
Black
Green is rpm limited
Okay thanks for the heads up, got one coming in next weekBlack
Black is limited as well but at 12k or a touch higher. You can lean them out a little with the L screw. It feeds into the H on those carbs. It may hurt response a little to get it where it's cleaned up on the top end when you do that.
I will have a look today at what coil is in it
Will try the low adjistment crew and see if this helps.
Reading that a walbro WG-8 is an adjustable carb for this saw.
$80 in the USA
Anybody tried this out?
Looks like rain today so no milling in the bush.
Maybe try some work at home if weather permits.
Going to try a 24" bar on it off the 61.
Will drag some logs over and see how it works.
As it is now my 070 will out cut this saw hands down.
12K for a 3130 thats howling I like it what wood are you millingMine goes way above 12k :/ so many variations with this saw.
I went to see Juan Carlos today at the husky dealer
He thinks it's the coil.
Not sure though he said.
Said this is 1st step
Black coil BTW. Iron.
He said 12500 rpm is what this coil is rated for.
I tried the L screw.
No different.
Finicky saw if it's not dialed in.
Juanca at dealer doesn't like this saw and kept saying 390 or 395 today is a better saw.
His reason was I could adjust in the field as needed.
I'm going to try another coil off a different saw that runs good and see if this solves the gagging top end.
Pura Bira as we say here boys & thank you
Getting hammmmmmered on a Friday night. Lol
Is all this happening to your 3120?! That sounds like it's going to be a monster frankensawThat was on the logosol running .325 chain, did that upto maybe 18" on sheoak. Don't know about jarrah, only put a tach on once. Did have muffler mod and a mild port I did.
Currently in bits, my carb is being modded for h jet. Ceramic bearings, 084 crank and port job will require it for sure.
Sounds like a beast I only cut jarrah myself. .325 chain yippeeThat was on the logosol running .325 chain, did that upto maybe 18" on sheoak. Don't know about jarrah, only put a tach on once. Did have muffler mod and a mild port I did.
It still amazes me how much the muffler restricts the saw .I realize it's the EPA even stillGood luck with the coil and getting hammered
Also perhaps try one cut with the muffler deflector removed. See if it's any better. If like mine, even the deflector was a restriction.
Is there another carb that can be adapted to it MikeYou can add an H screw to the carb. Usually have to clearance the filter box some for it
