Spike60
- 11:43 PM
- Feb 8, 2016
- Ulster County, NY
Don't think so. They use the rev limited green coil to control it.
Thanks bob, I assumed it ran an HD12. Never even gave it a second thought.There's the HD30 from the 375K power cut. Bolts right in with zero changes.
part number 503 281 811
Shhhh!!!! Can’t be giving out secrets. Lol
I know, I’m a slacker lol. I have an HD12 to test against the stock Zama, then I plan on modding the Zama. Just for gits and shiggles. Also have an HD30, not sure it’s worth throwing that in the mix. Mostly identical to HD12 except for a very small difference in main jet pick up size.Bump
The 390/394/395 carbs (both walbro and tillotson) are much better than the rwj4 on a ported saw if your wanting to do a straight bolt on without mods to the carb.Gets complicated. Tunability seems like the best benchmark for a "work saw".
It would be interesting to know when the 390/395 carbs actually put something on the table. Besides being heck of a lot easier to tune than a RWJ4.
Yes dyno testing would be great but I won’t be going that route, at least not any time soon. Hopefully there will be an appreciable difference in time/rpm for all this tinkerinNow that would be a great comparison, especially if it could be run up on a dyno. When Poleman did a comparison of a stock HD-12 to a modded Zama it was night and day. First he did a 30-35 on the 7900 then he did a 30-40 on the Zama - he was all for the 30-40 on the Zama for a 79cc engine.
I never knew if he cleaned up the venturi on the Zama for the tests. I don't think he did, if that is true, then there is that more than can be added to the equation.
Wood was clean and straight...white ash. I was surprised as well, especially after feeling like my saw lost some power when I first switched to the Zama. She felt good with both carbs, I knew it was close before I checked times. But, times don’t mean a whole lot to me, the difference was minimalThat's a suprise. Zama looked to pull great. Unless ya hit some kinda twisted grain with the Walbro.
Yup I’ve had that thread ear marked in my browser for quite a while. Thanks for posting. Info is info man, I personally don’t care where it comes from.Here is a link to where poleman posted his Zamia mods on AS. Wrong site I know but still good info there.
https://www.arboristsite.com/community/threads/zama-carb-mod-cliff-note-version.275905/
Yes it is. It’s identical to an HDA199 (357xp). It has that black spacer on the diaphragm side. No vent hole in the cover.The diaphragm vent is different.?
