Spike60
- 6:14 PM
- Feb 8, 2016
- Ulster County, NY
Don't think so. They use the rev limited green coil to control it.
Thanks bob, I assumed it ran an HD12. Never even gave it a second thought.There's the HD30 from the 375K power cut. Bolts right in with zero changes.
part number 503 281 811
Shhhh!!!! Can’t be giving out secrets. Lol
I know, I’m a slacker lol. I have an HD12 to test against the stock Zama, then I plan on modding the Zama. Just for gits and shiggles. Also have an HD30, not sure it’s worth throwing that in the mix. Mostly identical to HD12 except for a very small difference in main jet pick up size.Bump
The 390/394/395 carbs (both walbro and tillotson) are much better than the rwj4 on a ported saw if your wanting to do a straight bolt on without mods to the carb.Gets complicated. Tunability seems like the best benchmark for a "work saw".
It would be interesting to know when the 390/395 carbs actually put something on the table. Besides being heck of a lot easier to tune than a RWJ4.
Yes dyno testing would be great but I won’t be going that route, at least not any time soon. Hopefully there will be an appreciable difference in time/rpm for all this tinkerinNow that would be a great comparison, especially if it could be run up on a dyno. When Poleman did a comparison of a stock HD-12 to a modded Zama it was night and day. First he did a 30-35 on the 7900 then he did a 30-40 on the Zama - he was all for the 30-40 on the Zama for a 79cc engine.
I never knew if he cleaned up the venturi on the Zama for the tests. I don't think he did, if that is true, then there is that more than can be added to the equation.
Wood was clean and straight...white ash. I was surprised as well, especially after feeling like my saw lost some power when I first switched to the Zama. She felt good with both carbs, I knew it was close before I checked times. But, times don’t mean a whole lot to me, the difference was minimalThat's a suprise. Zama looked to pull great. Unless ya hit some kinda twisted grain with the Walbro.
Yup I’ve had that thread ear marked in my browser for quite a while. Thanks for posting. Info is info man, I personally don’t care where it comes from.Here is a link to where poleman posted his Zamia mods on AS. Wrong site I know but still good info there.
https://www.arboristsite.com/community/threads/zama-carb-mod-cliff-note-version.275905/
The diaphragm vent is different.?There's the HD30 from the 375K power cut. Bolts right in with zero changes.
Yes it is. It’s identical to an HDA199 (357xp). It has that black spacer on the diaphragm side. No vent hole in the cover.The diaphragm vent is different.?
