HELP! 372xp OE bogs under load
sunnyside
12:08 PM
Ontario Canada
Hi
I've a 372xp OE MMWS (Robin Wood) that bogs down under load. Idles fine, runs awesome at WOT. 3/4 throttle will run as long as it has gas.
I have; changed carb, pulled cap off fuel tank and held at angle to make cut, checked lines, done vac/pres test, no spark screen on exhaust. good air cleaner. changed fuel filter. Not sure what to check next.
I'm open for all options
CAMike
9:08 AM
Fresno
Yes the high speed adjustment screw is likely the culprit and last thing to do before replacing the ignition coil/module. I think you’re close to the end of your challenge.👍 Let us know how it ends.
