- 9:54 AM
- Jan 1, 2016
- Warren Center, PA
I bought a 2159 real cheap because of a bad coil. It is kinda rare though.I’ve gotten one bad one over the years out of 20-30.
Not mine, borrowed a pic. But if it were I’d keep itI'll take that 346 coil off your hands. [emoji16]
Black coil it is thenYou never know John!
Just soaking up some information.
I have a blue on a 372 that's marked 13100.
hoederI'll take that 346 coil off your hands. [emoji16]
Anything around 13 seems good for work saws. Most seem to perform best near the limiter so I follow along most times and tune right there near jingle bellsI have a blue on a 372 that's marked 13100.
Coils with retard up top do a little better with a fast chain imo.I did have one coil that had way more advance or something in it. It was good for 5% faster cuts swapping the coil only[emoji2371] I had to drill the holes to mount it on a 372. I never understood why or what it came from either. I should have kept it but I let it go on another 372 I sold
This is just a guess... There’s no wires or sensors on anything...(back then) has to be strictly RPM. Again, only a guessI'm just bored and mildly curious.... so the answer aint that big of a deal.
How the did the ignition know when "the saw comes under load"?
Manifold vacuum or was it like the auto-tronic stuff and compared rpm to throttle position?
IMHO as load increases on the saw, so does cylinder pressure. As cylinder pressure rises, so does resistance between the spark plug gap. The coil can sense the extra electrical resistance and adjust the timing.I'm just bored and mildly curious.... so the answer aint that big of a deal.
