346xp tank vent
redoakneck
11:33 AM
Ohio326
Does the white plastic piece with the gauze in it just push down in that hole?? or is there a tube??
Put some tiny o rings on the white piece and push it in???
Had a hose attached to it, not sure how its supposed to stay in if that is what goes in the hole??
Gary Courtney
10:33 AM
Froglevel
iplimage.php
P.M.P.
Stiff Member
11:33 AM
Michigan
The tank vent does have a hose that attaches to it and goes up through the carb floor to the carb.The vent pushes into the tank is all.
Gary Courtney
10:33 AM
Froglevel
mine does not have hose on it and it runs fine but this is where it goes
Gary Courtney
10:33 AM
Froglevel
I have one 346 that has a white tank vent and the a little plastic nipple next to it that has a return from primer and my other just has white vent
P.M.P.
Stiff Member
11:33 AM
Michigan
I have modded the tank vent on mine as well as a 357 which is the same.Heres a pic used the bailing wire to push it all out and then discarded the 2 pieces on the right.Then just push the gray looking cork back in.Also put a hole angled down in the tank in behind where the vent fits in recess.
redoakneck
11:33 AM
Ohio326
Ok, thanks. Trying to put a 357 intake on the 346, this should help.
Any other tips??? The 357 doesn't have a nipple on the air filter / carb plastic connector.
redoakneck
11:33 AM
Ohio326
So drill the angled hole where the white plastic piece pushes in, push white (after gutting) piece in with nipple pointing out , then hook up a hose. Since no nipple on 357, just leave end of hose in carb box???
11:33 AM
If I remember right I drilled one on an angle beside the original hole.
